what should my engine temps be? >
Old 08-21-2012 | 03:52 PM
Default what should my engine temps be?
I have a 31' scarab, 502 mags with prochargers. What temps should i shoot for and what temps are "too cool". I have a hard time getting it above 125-130. Seems thats now warm enough.
indysupra is offline
Old 08-21-2012 | 04:13 PM
F-2 Speedy's Avatar
F-2 Speedy is offline
Old 08-21-2012 | 04:34 PM
Lower temps with a Procharger is good IMHO......the "experts" out there will explain in detail........
FogduckerIII is offline
Old 08-21-2012 | 08:33 PM
Thanks so far.
Old 08-21-2012 | 08:47 PM
For reference my stock 575scis run 150 all day and up to 160 when ran hard. However, it's common to run hopped up blown engines with 130 thermos, assuming you ecu's are programmed for it, and your oil is still getting warn enough to burn off excess moisture you should be fine.
Is there a concern with how it performs?
4bus is offline
Old 08-21-2012 | 08:58 PM
No it runs fine just curious. I do hate getting on it when its barely above 100
Old 08-22-2012 | 06:35 AM
I would make sure my oil is up to temp before I jumped on it.
if your oil is up to temp, chances are your engine has been up to temp for a while.
Ken
minxguy is offline
