Tether Kill switch wiring >
Old 08-26-2012 | 12:06 PM
Default Tether Kill switch wiring
Purchased a new one off ebay to wire into my Baja which the PO had removed.. Problem is it seems like most i read were a normally closed switch, which opened the circuit when disconnected, and was inline with the purple wire for ignition.. The one which i recieved is the opposite, and is normally open, is there still a way to wire this in to work, or shall i chock up the loss and find a vendor for one of the other types?
andysperformance is offline
Old 08-26-2012 | 01:14 PM
You would need a relay to make it work, just more connections and more to go wrong. Unless its going to bust the bank you might call it a loss
kevinb230 is offline
Old 08-26-2012 | 01:24 PM
Return it.
Pismo10 is offline
Old 08-26-2012 | 01:31 PM
Sounds like a plan.. Just ordered another
Old 08-26-2012 | 03:07 PM
Rookie's Avatar
That switch grounds the coil to kill the engine.
Rookie is offline
Old 08-27-2012 | 07:09 AM
There are two types for inboard and outboard, one is NC one is NO
johnnywhale is offline
