260 mercruiser starting issue >
Old 08-29-2012 | 09:09 PM
Default 260 mercruiser starting issue
Got a 89 mercruiser that's impossible to get running unless I give it full throttel. But still have to crank it over for awhile. I changed rotor cap spark plugs an coil. Still having trouble getting it started but once it fires up it runs fine. I checked the acclrator pump
Seems to working fine on the qjet carb. What can I be over looking.
ctbs99xc is offline
Old 08-30-2012 | 09:00 AM
Spray Gumout down the carb, see if it starts normally. IF it does, it is a fuel issue, if you still have the problem then it is ignition. QJets hate dirt and clog up easy.
Pismo10 is offline
Old 08-30-2012 | 11:21 AM
I tried using staring fluid no luck finally got it running but took forever.
ctbs99xc is offline
