trying to get 700hp from a talldeck 540 >
Old 09-03-2012 | 10:32 PM
johnnyboatman's Avatar
Default trying to get 700hp from a talldeck 540
is this cam a good choice or would a bigger lobe be better this is a brodix headed 540 10.2.1 comp want 700plus hp help me out
johnnyboatman is offline
Old 09-04-2012 | 05:41 AM
Call Bob Madera "Marine Kinetics". He will get you going in the right direction. Really, really good person to deal with.
Cobra100+ is offline
Old 09-04-2012 | 06:49 AM
We just finished a 572 project with Bob that got us to 800 HP.
brian41 is offline
Old 09-04-2012 | 08:47 AM
yes ive talked to him already and got some good info from him.
just seeing what others think of this size cam.
Old 09-04-2012 | 02:16 PM
What rpm are you aiming for?? The lift numbers aren't crazy, but that's a lot of duration. You running dry tails? I'd think you would need 6k rpm's or more to get there.
BBCLiberator is offline
Old 09-04-2012 | 02:19 PM
No they dynoed to 5500rpm
Old 09-04-2012 | 02:25 PM
Is that the cam they used??? What did it dyno??? What did Bob say???
Old 09-04-2012 | 03:32 PM
bob says its to small, and the fuel is all phucked up, and its burning twice the fuel it should, he says the dyno was messed
Old 09-04-2012 | 06:25 PM
That's a bummer man, oddly enough my lift numbers are similar, your exhaust is higher, your duration is higher by about 15 degrees too, but for 700 hp, I would think you would need more too, but I'm no expert on cams. This sounds like a cam I could have used in my mild 502 if I had dry tails instead of standard risers. If Bob told you it's to small, then it is. Good luck sorting it out.
So what did it make on the dyno???
Old 09-04-2012 | 07:30 PM
620hp 650tq both are almost the same at 5200
