Are vortecs sufficient for a 383? >
Old 09-09-2012 | 07:50 AM
Originally Posted by 87MagnumII
Well after looking at the zz383 I'm thinking that thing would be a perfect drop in lol. Sure would save a lot of time and aggravation. Unfortunately I'm broke as a joke and will have to piece something together a little at a time as funds allow. I like the fast burn heads but was wondering if the 62cc chamber would be a problem when selecting a piston. The general has the CR at 9:1 with them but I'm not sure what piston they are using. I would like to go forged for sure. Also was looking at some edelbrock alum. heads, any thoughts on those?
I have the E-Tec 200cc heads and they work great! They were affordable and it made 440 hp on the dyno and pulled up to 5800 rpm
BBILL1174 is offline
Old 09-09-2012 | 08:48 AM
If I remember correctly, the limit of the stock valvetrain on the vortecs was a .480 lift. So you would have to disassemble and replace parts anyhow for that cam. What are you running for exhaust? That is the biggest choke point for the SBC world.
Jay Gadsby is offline
Old 09-09-2012 | 10:10 AM
That's what I'm looking for! Thanks!
Can you use self-aligning rockers with these heads or do you have to run guide plates?
87MagnumII is offline
Old 09-09-2012 | 10:12 AM
I've already got the valve guides cut down for more lift because I'm currently running the lt4 cam in my 350.
Old 09-09-2012 | 12:59 PM
I wil check w Jeff tomorrow I think they are self aligning
Old 09-09-2012 | 06:08 PM
You're half way there, a little port work would be cheaper for about the same head. If on a budget that would be fine.
CC230 is offline
Old 09-09-2012 | 07:04 PM
I've decided to toss the budget out the window and start pretty much from scratch. The only thing I will be reusing is my cam, intake, carb, and rockers, and block. Gonna replace the exhaust with some emi thunder and hopefully between the aluminum exhaust and heads take 150 lbs out of the back of the boat.
On another note, I have a performer rpm dual plane intake now. Would I benefit anything by going to a single plane intake? Also, will my demon 650 be enuff carb to fuel this thing?
Old 09-09-2012 | 08:26 PM
GPM
What are the specs on the cam ? you're adding a 1/4 of stroke, it will drop your top end down.
GPM is offline
Old 09-09-2012 | 09:42 PM
218/228 @ 50
525 lift with 1.6 rockers
Old 09-09-2012 | 09:54 PM
GPM
Tried one like that in my brothers 383 with 200cc Iron Eagles layed down around 4600 rpm.
GPM is offline
