509 starter replacement suggestion >
Old 09-23-2012 | 01:52 PM
Default 509 starter replacement suggestion
I need a new starter for a Merc. FI 509, 10:1 compression,
14 quart pan. Suggestions?
robmay is offline
Old 09-23-2012 | 09:24 PM
johnnyboatman's Avatar
just buy a marine gear reduction type,
johnnyboatman is offline
Old 09-24-2012 | 09:43 PM
rebuild the old one. it is more than enough for what your running
tunertech is offline
Old 09-25-2012 | 08:01 AM
I am having a hard time with starters on my 572. I'm sure the shop that rebuilds it for me uses Chinese drives cause it did not last 8 bumps of the key. I just put in a new gm starter for the 8.1 motor if you do a search I started a thread on this 2 weeks ago
zeke is offline
Old 09-27-2012 | 09:25 AM
CPPerformance's Avatar
These are one of the best starters we have found anywhere for high performance marine applications. Here's an option http://www.hardin-marine.com/p-13381...r-sbc-bbc.aspx
CPPerformance is offline
Old 08-04-2013 | 09:54 PM
zeke im having the same problems seems like the ones are cheap built and don't last, have you had luck with that one a buddy of mine said do the same thing but ive had my big ass (actually belly) in there till im sick of crawling in there. ive put 1.5hrs on a 42fountain in two seasons kinda getting pissed. paying payments and insurance to have it sit in the garage.
Old 08-04-2013 | 11:28 PM
Randy Nielsen's Avatar
The stock merc gear reduction starters have plastic gears in them so any kind of kick back will strip the gears. Not sure if there are any replacements for them that are any better. Maybe try Tilton or CPs starter (above post) price seems fair if they work. Randy
Randy Nielsen is offline
Old 08-05-2013 | 08:16 PM
MSD makes a good gear reduction starter that is offset to clear most oil pans. I have run it all year so far. I'm running a 598 ci at 10.1
vince1645 is offline
