525 rocker install/set. ? >
Old 09-25-2012 | 12:58 PM
Originally Posted by Griff
It can still be done with the intake on. It is just easier for somebody without experience to see zero lash as well as feel it.
Are you sure you got the correct intake or exhaust pushrod in the correct location???? They are different lengths.
Right rods in the right spots. No 5 Cylinder seems high. (8.255, long rod)Thats where the valve cover hits. Once I turn down the rocker nut, I think it will clear. The wear on the rod from the guide seem to be off about 1/8". I tried to push the lifter down, no play. Lifter will move when crank is turned.
My original thought was to do as much as I can, get the rockers pretty close, and then if I need to take it somewhere do the final adjust.
PARADOX is offline
Old 09-25-2012 | 05:27 PM
Mbam's Avatar
Offshoreonly Advertiser
I'm going to send you a PM
Mbam is offline
Old 09-27-2012 | 01:19 PM
Best advise yet.
PARADOX is offline
