bravo-trs flywheel difference >
Old 09-26-2012 | 07:05 AM
Default bravo-trs flywheel difference
is the only difference in the stock flywheels from a bravo to a trs with top mount starter the ring gear location on the flywheel? can the ring gear be moved to the other side of the flywheel for a bravo app?
88bullet is offline
Old 09-26-2012 | 04:11 PM
yes...but dont reuse the old one,,go to napa and match up a new one..put flywheel in the freezer over night,,take a map torch and warm up the new ring in a circle motion..take flywheel out of the freezer and the ring should drop on..let it get to room temps b4 touching it...
FIXX is offline
Old 09-26-2012 | 11:31 PM
You will probably need to cut the flywheel down on the front side to accept the ring gear. If the flywheel was originally for a TRS, then it will not have the proper shoulder on it for the ring gear to go on the front side.Any machine shop with a lathe with at least a 14" swing can cut it for you. It's a pretty easy job.
Eddie
Young Performance is offline
Old 09-27-2012 | 05:29 AM
the low mount starter is a pass car-truck style set-up. i would think a replacement flywheel would be cheaper than having one machined to accept a new ring gear which you still hafta buy...
dereknkathy is offline
Old 09-27-2012 | 10:13 AM
machined and ring gear installed... 70 bucks. my old shop teacher from highschool has a machine shop in his back yard. flywheel going in tonight
88bullet is offline
Old 09-27-2012 | 03:54 PM
my old trs boat had the lip on both sides..
FIXX is offline
Old 09-27-2012 | 04:02 PM
I thought we already taked about this bullet
4bus is offline
Old 09-27-2012 | 09:16 PM
i pulled the motor and changed the flywheel today. worked perfect!!
4bus i started this thread right after i sent you the first pm on it. as soon as we finished our conversation i got some responses on here lol. we put the race boat in for the sea trial tonight. boat hasnt seen water in years. ran incredible!!
88bullet is offline
Old 09-28-2012 | 09:08 AM
Hardly. I replacement flywheel with the ring gear on the back side is pretty costly. Expect to pay around $400, since they are not very popular. A replacement ring gear from Napa is about $20. As the op stated, it cost him $70. Definitely the cheapest and quickest way to go.
Eddie
Old 09-28-2012 | 09:20 AM
google search i was finding flywheels from merc for 750.00.. i almost sh!t myself when i saw that. or searching for a flywheel that "should be right". this way i have the flywheel that was balanced with the motor. and works like a dream.
thanks for the input guys!
88bullet is offline
