most power out of 454 Mark IV ?? N/A
#51
#52
#53
I built a 468 for a 26 Baja for a friend of mind in St.Clair Michigan years ago. Engine was 8.75:1 comp. with full ported 990 GM iron heads, SuperChiller, B&M 420 blower with twin 800 cfm Holley carbs. With 9 PSI boost on 91 octane made 850 HP at 6500 rpm. Boat ran 92 MPH and you better have BIG balls to run it!
#54
460 CI with 110CC domes
Merlin heads, I still need to verify runner size but last we talked I think we were thinking they are the 345cc runner (huge)
420 cams as of now... 228/236
Holley single plane intakes
800 cfm Holley HP500 carbs
heads are put of the box right now and I swear compression is 8.4:1 from what I remember..
as of now I have pushed the Mistress to a best of 65 MPH @ 5000 with 24P Quicksilver props... actually good numbers for a Mistress with the power it has..
let me know thoughts Dean... thx
#55
Piston domes come more in the range of 20-50cc's. A .030" over 454 zero decked with 24cc domes would be 10:1 compression in 119cc chambers.
What pistons/compression is your buddy running that made 521hp with the stock heads and dual plane and that Edelbrock cam? What stock heads did he have? Anything else?
#56
B=345cc
C=310cc
D=269cc
#57
#58
I will have to see if I have any pics to see, I swear when I was trying to figure it out there was no tell tale way besides CC them..
#59
One of my engines have the KB KB-203 pistons, 12 cc domes looks like, no idea what I was thinking 110 cc lol
the other engine has the forged TRW same dome, I dont have that part number handy yet..
#60
If the blocks never been surfaced(pistons .020 in hole), or the heads, using a standard .039 Fel pro gasket, 119cc combustion chamber, that would be around 8.65:1. I'd imagine though the blocks and heads have probably seen some surfacing in the past, esp since they already been bored. Prob somewhere real close to 9:1 as they sit.
