Comp Cams Rockers >
Comp Cams Rockers
Comp Cams Rockers
Old 10-03-2012 | 06:52 PM
Default Comp Cams Rockers
Anyone have fitment issues with the newer Comp Cams Ultra Gold ARC rockers under stock merc. valve covers?, the rocker arms themselves clear but the locks do not.
RAPTOR1 is offline
Old 10-03-2012 | 10:11 PM
I believe one of the members recommended a double-thickness valve cover gasket from Summit (?) I think.
Wes Burmark is offline
Old 10-04-2012 | 12:35 PM
articfriends's Avatar
I have taken the factory vc with o=ring and sealed it to a extra thick rubber steel inserted vc gasket with great stuff and it sealed perfect, has cleared stud girdles, t/d shaft rockers etc, I also took air sander and sanded off the oil drippers inside them, Smitty
articfriends is offline
Old 10-04-2012 | 05:44 PM
28Eliminator's Avatar
As Smitty did, I had to grind off the oil drippers on mine, but the locks still won't fit on stock VC's. The locks are way longer than they need to be. There is a guy down the street that has a mechanic shop with a metal lath and I paid him $40 to shave the the 8 that stick up the highest (intake or exhaust), and they have work perfect under the valve covers. Maybe someone makes a shorter lock!
28Eliminator is offline
