Need flywheel advice >
Old 10-07-2012 | 06:31 PM
cleaned up flywheel in freezer and ring gear in oven, have flywheel near oven. don't want it to cool down, then knock it down evenly with hammer. have good gloves for heat.
keith2500hd is offline
Old 10-07-2012 | 06:48 PM
Also don't drop it on the kitchen floor or a bad ring gear will be the least of your worries. Also make sure you put it on the right side it came off of.
f_inscreenname is offline
Old 10-07-2012 | 09:17 PM
a piece of plywood or a couple of pieces of 2x4 lumber on floor in front of oven.
dereknkathy is offline
Old 10-08-2012 | 10:46 AM
Sounds like loosing teeth is more of an issue than I thought. Lots of experience here. Thanks guys.
Sledge Hammer is offline
Old 10-08-2012 | 04:54 PM
actually i just do car front wheel bearings this way. a friend used to put hubs on rotor shafts for helicopters back in conn same way. he had 10 seconds to get hub on shaft. if not down all the way, it was expensive scrap metal.
Old 10-09-2012 | 03:09 PM
If your doing it on a damp day, wipe off the condensation off of the flywheel before you drop the ring gear on. I used to do Piston pins this way without an arbor press. We had some damp days and the condensation cooled the rods too quickly, had to take them to the machine shop anyway.
ThisIsLivin is offline
Old 10-09-2012 | 04:33 PM
GPM
It's not that difficult
GPM is offline
