Twin prop rotation >
Twin prop rotation
Twin prop rotation
Old 10-05-2012 | 05:32 PM
Rookie's Avatar
Not dangerous, I have a friend that had a 32' Pachanga with twin Alpha's that both spun RH rotation. No ill effects. But if you have Bravo's just do it right.
Rookie is offline
Old 10-05-2012 | 08:24 PM
Originally Posted by MissBehavin777
WOW... Don't do that. Dangerous and real bad idea. Sell one to buy the other. Spin out
No such thing as a left hand or right hand Bravo 1. Their all the same. Rotation is determined by the cable connection on the shifter at the helm. Can certainly be changed easily. Beings it's a Bravo set up I think I would change it. Must not be much of a problem though if it's been run like this so far. I also have a friend with twin RH Alpha's on a 30 footer and has no complaints.
picklenjim is offline
Old 10-06-2012 | 02:03 AM
Originally Posted by JETTDOGG
is it hard on the drive?
I'd heard it could be done-but my mechanic frowned on it
Your mechanic is not very smart then.
Nearly all twin engine boats with Bravo drives run with standard rotation engines and change prop rotation by reversing the drive rotation. Bravo's can spin either way.
Griff is offline
Old 10-06-2012 | 03:18 AM
Spin them out.
Pinkley933 is offline
Old 10-06-2012 | 11:23 AM
THANKS ALL - MY MERC GUY IS MOSTLY SINGLE/FISHIG/ETC JUST VERY CONSERVATIVE - RAISED HIS EYBROWS AT PUTTING A BIG BLOCK IN MY OLD 24/7 ...TOO MUCH POWER
BUT HE IS A GREAT WRENCH
ANYONE HAVE A HYDRMTV QIV 23 LH
JETTDOGG is offline
Old 10-08-2012 | 05:48 PM
What are the advantages or disadvantages to spinning them out rather than in?
ondtip is offline
Old 10-08-2012 | 06:03 PM
Out=Stern lift. In=Bow lift.
Normally in is faster on most V bottoms. Downside is reverse around the dock can be tricky.
MILD THUNDER is offline
Old 10-09-2012 | 07:37 PM
the boat will also lean over a lot more in turns, can be dangerous if you don't know what you are doing. Mine spin in, I get slightly better mpg, same top end though. Docking is a little tougher but I have gotten used to it. I did it for the bow lift.
pstorti is offline
Old 10-11-2012 | 08:41 PM
jet what year is your boat?
ext2gtx is offline
Old 10-12-2012 | 04:36 PM
Ext
1980 scarab-s 30'
JETTDOGG is offline
