Power trim hoses...  LONG... who makes them? >
Old 10-16-2012 | 08:44 PM
Default Power trim hoses... LONG... who makes them?
I'm in the need for some longer than 72" long power trim hoses . . . does anyone make these, even custom if needed?
Mario L.
Mario L. is offline
Old 10-16-2012 | 08:49 PM
Registered User
Pretty much any ag dealer ( john deere, case ect.) can make custom length lines & various size hoses, probably the most inexpensive you will find.
GTOKILLER is offline
Old 10-16-2012 | 10:16 PM
Default Fixx
Mario L.
merc boes..if you need them real long then you buy another set and add a line connector to make them longer..if custom made they may not be stainless steel..ask george carter where he had his made for his testrosa...
FIXX is offline
Old 10-16-2012 | 11:54 PM
CP Performance will make any length with any configuration of ends that you need. They are SS braided hose with SS ends in either straight or 90* config. Call and speak with Mike at ext. 217. (1-800-225-9871) Tell him I sent you and he will fix you up.
Eddie
Young Performance is offline
Old 10-17-2012 | 06:08 AM
c_deezy's Avatar
Parker makes a PTH-3 hose - PTH = Power Tilt Hose. A trip to your local Parker shop should be able to get you fixed up.
http://www.parker.com/portal/site/PA...0032a71dacRCRD
c_deezy is offline
Old 10-17-2012 | 06:13 AM
c_deezy's Avatar
You could also run hard lines, with a flex line at the ends to get to the drives/pumps.
c_deezy is offline
We have used Bonco hydraulic's (909-985-3429) for several projects when relocating pumps or custom installs, always fast service and good quality.
brian41 is offline
Old 10-17-2012 | 07:14 AM
Sydwayz's Avatar
Forum Regulator
You can check with your local Napa. If they can't make them, they can probably point you to someone industrial/agriculture who can.
Sydwayz is offline
