Engine sync gauge or????? >
Old 10-17-2012 | 06:53 PM
Default Engine sync gauge or?????
I am in the process of replacing the dash in my scarab and I have a VDO engine sync gauge. It is the large cut out 3 1/2" or so and it is between the tachs.
First, is there anywhere to get a replacement for this? Second, if not what to put in it's place????
I already have the tachs and gps speedo, the sync gauge is ugly as all hell so I do not want to keep it but I can't seem to find one, or have any ideas of what to replace it with.
Baja226sport is offline
Old 10-17-2012 | 07:40 PM
A g-force meter lol......how about onr of those multi gauges for dual water pressure and engine oil temp??
FIXX is offline
Old 10-17-2012 | 08:23 PM
Hmmm....that could be a possibility. What to do with the oil temp gauges then?
Old 10-18-2012 | 04:02 PM
Has nobody else had this issue?
Old 10-19-2012 | 08:53 AM
Keep it. There are replacements out there. The sync gauge is much more accurate for syncing your motors then looking at your tachs. The sync gauge is a direct differential between the RPM signals from your motors, and not an interpretation of them.
Redhook98 is offline
Old 10-21-2012 | 06:14 PM
So where can you get a replacement? I am not even considering keeping this old beat up thing I have now!
Old 10-21-2012 | 06:50 PM
Can you post a pic? Have you tried Ebay? Have you looked around online? On my last two boats, I had no problems finding new Sync gauges. Even if it does not match the other gauges perfectly, you still want one. If it's a VDO, then they are out there.
Old 10-21-2012 | 08:43 PM
Registered User
I have a sync gauge too. I was thinking of installing the larger 5 inch gauges to replace the tachs and speedo...haven't checked to see if they will fit yet. Of course the 5 inch gauges mean a new pdash panel...ugh
scarab31 is offline
Old 10-21-2012 | 08:47 PM
Put a clock in. If you can't sync by sound go back to a single...
No offence to you personally. Just a general statement...
POWERPLAY J is offline
Old 10-22-2012 | 06:44 PM
This thread was not about actually needing a sync gauge, it was what to fill the whole with that is going to match the new dash.
I didn't know if gaffrig/livorsi/auto meter made on that I could get. A 3 3/8" clock would be stupid, I don't like the idea of a blank, I will figure something out I guess.
