500 efi compression >
500 efi compression
500 efi compression
Old 10-20-2012 | 02:05 PM
bmc
Default 500 efi compression
Dose anybody know what the comp. per cylinder should be on 500 efi fresh rebuild, I am pumping oil out of the dipstick and valve cover vents. One cylinder only has 100 psi all the rest have about 148 to 150.
bmc is offline
Old 10-20-2012 | 04:26 PM
It should be a solid 150. The 100psi cylinder definately has a problem. Do a leak down test on that cylinder to see where the air is escaping.
Griff is offline
