bellows leak?
hey guys,
while winterizing my boat i noticed on my port side motor when the anti freeze would go thru the muff up thru the out drive (alpha 1 as far as i know) just before it went into the transom a little constant stream would spit out just before entering the boat.(it did not do this on the starboard side motor) is this a bellows (hose?) leak. mind you this is on the same side that the Trim stopped going up and down slowly while cutting out as well as does not go in reverse (as far as im told, from the guy i bought it off, it needs a new shift cable). not sure if it has anything to do with it but you never know the more information the better the answer ill get
It wouldn't be the bellows. From what you say I would think it has a leak in the hose that runs between the bell housing and transom assembly. Part #17 in the diagram.
http://www.perfprotech.com/mercruise...03/60?model=77
Or if it's spiting out between the drive and bell housing then it would be o-ring #9.
first, alpha as far as you know. you need to know. ebay search. alpha drive and bravo drive. look at the pics of both. compare. now you know. it is gonna be hose or o-ring as pickle said. do both shift cables, gimble boots, hoses mentioned prev post, and shift boots. whatever is bad on one side is dying on the other side. and make sure you get that one drive trimmed down for the winter. don't leave them up. in fact, you might wanna spend the winter shopping for spare trim cyls.
