Which flywheel for bbc >
Old 11-05-2012 | 08:14 PM
Default The End
Got it
427 or machine one to neutral.
Thanks to all!!!!
Flying Tomato is offline
Old 12-18-2012 | 08:23 AM
Similar issue. Rebuilding a pair of GenV 540's. Appears the previous builder internally balanced the engines, but used externally balanced flywheels and harmonic balancers. Not sure how this happened, but might explain why the port engine spit a main bearing out into the timing cover after 200 hours. Anyhow, I need two neutral balanced flywheels. Will the 427 application work for me too? Thanks.
jamontes is offline
Old 12-18-2012 | 09:24 AM
yes,396 or 427,both are internally balanced.
mike tkach is offline
Old 12-18-2012 | 09:25 AM
2 peice rear seal 350s will also work.
Old 12-18-2012 | 10:09 AM
Even on the GenV one piece seal crank? Also is there a special pattern for the coupler? Thanks.
jamontes is offline
Old 12-18-2012 | 04:55 PM
Default fixx
the one piece has a smaller bolt pattern
so it wont work..
FIXX is offline
