Gil Exhaust mod.... >
Gil Exhaust mod....
Gil Exhaust mod....
Old 11-27-2012 | 09:07 AM
Links for earls and summitracing. #18 hose
http://www.holley.com/types/Auto-Flex%20Hose.asp
http://www.summitracing.com/search?k...06018ERL&dds=1
F357 is offline
Old 11-27-2012 | 10:25 AM
The problem I am having is sourcing the an-18 stainless weldon bungs....
I am cutting the hose adaptors and welding the male an18 bungs on the gils, tstat housing and manifolds...
commandersander is offline
Old 11-27-2012 | 10:57 AM
No need to do it that way use the same ends on the hose mercruiser
Uses on the hp 500s if your trying to put an fittings on the ends
I don't think they are available
smokin' gun is offline
Old 11-27-2012 | 12:20 PM
From the link I posted in the other thread
*No hose ends available for hose sizes 3, 5, 7, 9, 11, 14, 18, 28, & 32. These are to be used with Earl's ECON–O–FIT or hose clamps only
Griff is offline
Old 11-27-2012 | 06:37 PM
Seems to me like a void in the market.
If I made these, do you think there are enough buyers for it?
Old 11-27-2012 | 08:42 PM
no. waste of time .just use the econo fit hose ends .hell its good enough for mercruiser . by the way i made your adapters today .rabbit on 1 side for air cleaner and other side to fit 4150 .cant buy these anywhere
Old 11-27-2012 | 09:11 PM
Default Cause yer tha phuckin man!
As above!
Old 11-27-2012 | 09:17 PM
Default Patent by recognition
I acknowledge that the image above is proprietary and singularly the sole possession of Gordon ************ of OSO fame and any duplication of or reproduction in part or whole is an infringement on his intellectual right and he as the creator should be justly compensated for any and all imposed and implied infringement.
We will not return you to your regularly scheduled programming.
Old 11-27-2012 | 11:01 PM
I could use some clarification from folks that are familiar with Gil exhaust. I have a set of Gils that I run with a freshwater full system. I have blocked off the small hose to the riser as it is coming from the manifold that has fresh water circulating. I noticed that, even before the full system was installed, the risers would get hot and you would not want to get too close or you would be a warm arm. What is the recommendation for the small hose if you have a full system freshwater cooling. I could not come up with a better plan and could use some suggestions. Thanks
goin70 is offline
Old 11-28-2012 | 12:59 AM
Ditto. Those are the fittings in my 525SC pic above.
Griff is offline
