Instrumentation anywhere you wanted
Finally found a forum where someone had called the manufacturer and got prices from them. Your looking at about $375 each for a 3" stroke model!
Maybe pricing would be a bit cheaper through a supplier or for larger quantities but for this to make sense for me they need to be around $100 each!!
Oh well
Well that's what I figured! I couldn't find there prices listed on any sites, they all said call for pricing which is the first sign that these things are pricey!
Oh well
Oh well
It isn't cheap. I will check some of my other suppliers and see what I can find out there.
Oh well
Oh well
That is the problem with dealing with distributors is they only send you what you ask them for, them don;t make sure you are buying the right thing.
Your part number is MLP-75 ( this is a 0-3" sroke range), A 15' extension cable to get back to the dash is gonna run about $79+-, The signal output, and connection type is going to range from $44-154 depending on how it was designed.
I never said any of this was cheap, but it is cool stuff.
Oh well
Oh well
Theoretically, this is a good alternative for fuel level. Hydrostatic technology uses the weight of the fluid above the sensor to calibrate the volume of fluid in the vessel. Need to do a little more research as to weather the motion of the boat will throw it off, but it already throws off the floats anyway....
These measure down to an inch or less of fluid all the way to thousands of feet deep.
http://www.pmc1.com/Capability.asp?C...1149&Cat1ID=79
