Instrumentation anywhere you wanted
#31
There has been a lot of talk about NEMA on this thread. I have custom motors and unless they were built by merc then they wont be Nema compatible. I would love to have a digital display but my understanding is that I cant due to the electronics
#32
With the instrumentation he is talking about the sky is the limit. A controller and display will be needed I prefer them to be CAN (J1939, J1979, J2411) this way you will have a ton less wires going to the helm and many other reasons as well.
#33
You should have a look at www.maretron.com they have NMEA compatible systems that can monitor just about every parameter you could ever want on a boat. They use ultrasonic sensors for tank level monitoring. They also have several displays in addition to all the sensors. Do you sell or rep any 4-20ma pressure transducers, 0-50psi, 12v?
I can fix you up, just need to make sure we give you the right parts. All of ours use Ceramic diaphrams for longevity, and a titanium housing option for a 5 year corrosion warranty. Currently we are showing an average mean time between failure of 10-12 years in zero maintenance environments.
We have optional Kynar housings as well for hot acid applications.
#34
If you really wanted a digital display you can have one. I plan to instrument every aspect of my engines this year. I will not be using a display rather than a lap top so all this info can be recorded and played back. If you are familiar with how the car OEM's collect data and perform vaildation it will be similiar.
#35
Load sensors can be engineered into the drive housings to determine bearing and shaft movement, but this would be expensive.
Need someone with an R&D budget to do somethiing like this.
#36
I can engineer all of this stuff for CAN output, If you want to work on a project together then give me a call. The main road block on this project for us is the cost of the test bed, sensors for this type of project I can get us a discount on. We just need to work on the engineering, and eventual data sharing with the independent manufacturers.
Jason
#37
Starting simple with drive temp T couples, engine oil T couples, pressure sensors in various places etc for right now.
Using a simple 16 channel data taker with USB output.
#38
We are looking at a Merc powered DOnzi right now to add some stuff to, but will not be modifying anything to do with the current merc stuff.
I plan to have this all sync'd with what the engine is doing so I can collect the data and play back to see how things were running.
What software are you using? I prefer Ipemotion.
#39
I have enough daq's to do 64 thermal couples, type T and K along with 24 various sensors ( pressure, amp, position etc).
If you need a good outlet for T couples, then let me know. I was going to try staring with the washer type under a bolt, and go from there.
We are reps for Nanmac, PMC, STS, Hoffer, Wilcoxon, Celesco among others. Lots of signal conditioners etc.
http://www.talontechsales.com/
My new website wont be out until first quarter next year.
#40
Yes, but I need the fluid to be measured, process fitting, output pressure range, cable length etc.
