View Poll Results: 114 or 112 for low rpm power
114
15
45.45%
112
18
54.55%
Voters: 33. You may not vote on this poll
Cam LSA
#51
Good post Joe. Maybe we can all get along now. Me, you, mrfixxall, mike Tkach , and Jeff Armstrong. Sooner or later we're all gonna be on a poker run together.
Maybe if you get these engines straightened out, you'll finally be able to keep up with mike Tkachs fountain .........
#53
#55
#56
#57
spinning 4200 RPM now fruitcake but thinking if i drop the gear ratio and put a set of 22 3 blades on so we can wind em up to 7500 ,I'll give Rob M a call this a.m. and see what he thinks lol
Tunnel good luck on your new combination see ya on the water and Happy Holidays
Jeff A.
Jeff A.
#60
The cam in discussion was for a procharger engine. His problem was idling issues, and getting on plane. Engines made 1300hp at 6500,, torque peaked at like 1083ft lbs at 5900. However tq a 3500 was 788. That was where they started the pull, but my guess at 3000 he was barely making 600ft lbs when not making boost. Planing with 120mph props with 600ft lbs on tap wasn't very impressive to say the least.
These are very low 7.8:1 static 522's. his duration was 252/262 on a 114. My overall advice was to bring the duration numbers down, to help build some cyl psi down low. The torque peaks right now where his hp should. Not enough static compression to be runnin the cam he was in a marine 522. Just my thoughts but I'm no expert .
