View Poll Results: 114 or 112 for low rpm power
114
15
45.45%
112
18
54.55%
Voters: 33. You may not vote on this poll
Cam LSA
Old 11-28-2012 | 03:08 PM
Default Cam LSA
Having a friendly discussion with a buddy. On a low compression, 12lb boost engine, which LSA would make more torque down low? 114 or 112?? Given duration and lift being equal.
I say 114, his cam guy tells him 112 would make more power down low. Feel free to vote on which cam you would pick if low rpm torque is what you would be seeking. Feel free to explain also.
MILD THUNDER is offline
Old 11-28-2012 | 05:11 PM
http://forum.grumpysperformance.com/...hp?f=52&t=1070
There have a read...and some asprin.
Pliant is offline
Old 11-28-2012 | 07:24 PM
114* cam advanced 2*..stump puller! 114 because theirs more distance between the intake and exhaust which will allow a little more ait in the cylinder then the 112 cam..more air and fuel sooner = mo power quicker sooner etc..you know the drill
FIXX is offline
Old 11-28-2012 | 09:38 PM
Sounds like a great question for RMBuilder. I think I asked Bob a similar question, but cannot recall his exact answer. I'm pretty sure more overlap tends to move the power band higher in the RPM range, which would make sense when you look at the profiles of the drag racing style cams with small LSA of 108* and 109*, compared to the RV type cams that usually have 114* or more.
Budman II is offline
Old 11-28-2012 | 09:44 PM
I agree, this would be a great topic for Bob!
endeavour32 is offline
Old 11-28-2012 | 09:49 PM
+1
sprink58 is offline
Old 11-28-2012 | 10:12 PM
Most RV and towing cams are ground on a 114. Most drag race cams are on a 108-110. Most supercharger cams are also 112-114 because less boost gets pushed out the exhaust valve during overlap.
So why would a narrower LSA provide more low end torque? I'd like to know why.
Old 11-29-2012 | 02:13 AM
Griff is offline
Old 11-29-2012 | 08:05 AM
114 hands down....but Bob is the man on this !!!!
ezstriper is offline
Old 11-29-2012 | 07:40 PM
GPM
Back to back dyno pulls I did, the 114 had less bottom and midrange than the 112, took 4 seconds longer to make the pull but carried the HP 200 RPM further. Same grind solid roller just different LSA.
GPM is online now
