drive and tab cables >
Old 12-03-2012 | 01:02 PM
Default drive and tab cables
Just removed trim and drive indicator cables , they have 3.70inch of travel and have ultraflex USA stamped on them and are dark blue . i have googled them but cant find anything . most of the cables i come across only have 3 inch travel . Thanks for any help.
paul buckner is offline
Old 12-03-2012 | 05:21 PM
mcollinstn's Avatar
Standard Teleflex "nothing special" cables have always worked fine in my experience.
Not sure why you would need an oddball travel. And 3" sounds short - you sure a regular cable doesn't have more?
If you have a tight kink with the drives in trailer position, you may want to upgrade to an Ultraflex, etc to keep them from getting a permanent kink and damaging the outer housing.
MC
mcollinstn is offline
Old 12-03-2012 | 05:57 PM
The 3300 and 4300 teleflex cables all have a 3" travel. The 6400 series cables have a 4" travel.
The 3300 can be found here... http://sierramarine.com/sierra/searc...alog00204.html
The 4300 & 6400 can be found here... http://sierramarine.com/sierra/searc...alog00206.html
502ss is offline
