Shaft mount roller rocker arms >
Old 12-06-2012 | 08:15 AM
Default Shaft mount roller rocker arms
Wanted to throw this out there and see what the marine industry prefers. Is it prefered to use a stainless steel or aluminum shaft mounted rocker arm? The big players in the industry off both. Just curious what is used regularly in the marine industry.
Jason
Jason3603 is offline
Old 12-06-2012 | 05:45 PM
No one uses shaft rocker arms? If not what do you guys use in big HP motors?
Old 12-06-2012 | 06:03 PM
I prefer T&D shaft rockers but the amount of money they cost most will go with a crane style rocker..
FIXX is offline
Old 12-06-2012 | 06:13 PM
DesertRage's Avatar
I believe it comes down to lifecycle and cost of the rocker arm. Depending on spring pressure, the aluminum version will eventually fatigue and crack, but comes with reduced weight as compared to a standard stainless arm and at a better price point.
Shaft mount rockers are a custom piece and come with many avaliable options if you want to pay for them. Stainless will be heavier unless you opt for a lightened version and will outlast the aluminum in terms of hours...
If your interested in a new set contact Bob Madara. He recently supplied me with T&D's and I couldn't be happier!
DesertRage is offline
Old 12-06-2012 | 06:21 PM
i run jesel shaft style due to solid roller high lift and high spring rates .i also run lash caps .2 seasons now the lash hasent moved .the system is nice and as others have stated expensive
smokin' gun is offline
Old 12-06-2012 | 06:46 PM
T&D #3116 = $1363.10 a set . 2 week's delivery . What the hell it's christmas
Jeff P31 is offline
Old 12-06-2012 | 06:58 PM
I dont think its as much as a ''HP'' question, as it is a setup question. Point being, if your running a high lift solid cammed setup with lots of spring pressure and RPM, then you'll want either shaft rockers, or a good stainless rocker. If your running a moderate hyd roller, mild spring pressures, and mild rpm, a aluminum rocker will work fine.
Crower makes a nice stainless rocker. Crane, and Scorpion make nice aluminum rockers.
I just replaced two sets of crane gold roller rockers. They were stamped 1985. They served their purpose for 27 years. out of 32 rocker arms, two had cracked trunnions. Replaced with same crane golds, just newer. The newer versions are much beefier than the old ones.
MILD THUNDER is offline
Old 12-06-2012 | 08:06 PM
Rookie's Avatar
http://www.offshoreonly.com/forums/g...life-span.html
Rookie is offline
Old 12-06-2012 | 08:13 PM
I had a valve break and after Ferrea inspected the valve the conclusion was valve train instability. It was recomended I stabilize the valve train by going with a minimum .120 push rod and shaft rockers. Since I like to know the options of whats available rather than take someone's word for it, I typically do a ton of research. I like to make a well informed decision. I seen most manufacturers offer shaft rockers in aluminum and stainless. So I thought I would start a thread about it to see what was preferred throughout the marine industry.
Old 12-06-2012 | 08:16 PM
Thanks for posting the link. A lot of info in there. Pretty much answers all of my questions. Thanks again.
