Causes of tight wrist pins and scuffed pistons ? >
Old 12-11-2012 | 12:30 PM
  #41
Originally Posted by supermx96
Mine is set at .050".
I keep .010" on block deck for future deck squaring and use .040" head gasket.
Oups miss understanding, excuse my english.
supermx96 is offline
Old 12-11-2012 | 03:15 PM
  #42
blue thunder's Avatar
.004 is way too tight on an open cooled marine SC engine in my .02. That would be the root of the problem. Easy fix though with some new pistons. If you are going with a bigger blower, than the new pistons give you a chance to lower compression a bit anyway. The little blower needs the squeeze though, so if you are staying with 174 I'd go up in compression. And of course you need to set the quench to .040
blue thunder is offline
Old 12-11-2012 | 07:58 PM
  #43
I had very bad luck with the 250 B&M blowers and I NEVER will run a blower without duel carbs. Ever. Period! Always leaned out Cyl. 5 and 7. Too much heat.
mj2562@bellsouth.net is offline
Old 12-11-2012 | 08:10 PM
  #44
I agree litle blower make much heat but the B&M 250 depending on the engine ci and blower rpm could make some great power at 7-8 lb boost non intercooled.
I also had issue with my B&M 250 blower on 454ci with single carb setup and offset carb plate, all 4 rear cylinder was lean. I will run twin carb setup now.
Old 12-11-2012 | 08:42 PM
  #45
Has for the wrist pin i have notice on my engine that i had a tight pin in the melt #6 piston, that is normal after a melt piston, but if lil red have 7 on 8 tight piston wrist pin and had only 3 scuffed piston (surely due to a piston wall clearance issue), no sing of detonation what can make that tight wrist pin???
Can be not enought clearance between wrist pin to clearance in piston during the assembly??
Old 12-11-2012 | 09:20 PM
  #46
That is one thing I'm still wondering, I did not have a chance to call dean yet, speaking with one engine builder, they had found too smooth of a cylinder wall finish to not retain enough oil and cause issues. This was on high ductile dart blocks that clog up typical fine honing stones and should not be an issue with an oem block
Unlimited jd is offline
Old 12-11-2012 | 09:23 PM
  #47
Originally Posted by lil red
Not sure on the quench I'll have to check upon reassembly, the rings and ring lands look fine.
Maybe I just don't want to believe it, but I've run a lot of big power motors, granted not many in boats, but there are no signs of detonation anywhere on these. I've detonated pistons into a million pieces, and I've made some last that should have blown up right away. How could it have beat the wrist pin bore out of the piston without a single sign on the plugs, bearings or domes??
The upper rod bearing will tell you long before the piston will if you are detonateing in a boosted motor.
Villian III is offline
Old 12-11-2012 | 09:27 PM
  #48
, they had found too smooth of a cylinder wall finish to not terrace rain enough oil and cause issues.
Are you saying you need umbrellas on your pistons? Or its raining out on your terrace?
MILD THUNDER is offline
Old 12-11-2012 | 10:01 PM
  #49
Lmao damn smart phone!!!
Not retain enough oil!!!!
Old 12-12-2012 | 01:04 AM
  #50
If you notice those pistons have the small grooves machined in the skirts to retain oil between the piston and cylinder. Those really aren't that great of pistons but I don't think that was the problem. In my opinion it was all due to poor machine work. If you have the ability to double check the specs of the machine shops work before assembly than you know everything should be fine. Most people don't think twice about doing this. Here's the piston clearance specs from the merc manual.
Attached Thumbnails Causes of tight wrist pins and scuffed pistons ?-skirt-grooves.jpg   Causes of tight wrist pins and scuffed pistons ?-clearances-r.jpg
picklenjim is offline
