Anyone Tried Extractors?
they work fine on drag engines that only see a few seconds of WOT but when run for extended periods they can pull oil from the wrist pins and cylinder walls. NASCAR engines run pin oil drilled rods and oil squirter for the bottom of the pistons, etc, etc, so they can use them without issue. if the engine is not set up for all the additional oiling then the evacuation can cause more harm than the few HP you would gain. just my .02 cents though.
I am going to be running Total Seal MAXXSeal rings on this rebuild. I don't foresee a blowby problem with those but a little extra HP never hurts. I toyed with the idea of a vacuum pump on the previous motor due to the hardened race rings it used to help them seal.
