500 EFI Fuel Rail Schrader Valve question >
Old 12-11-2012 | 02:59 PM
Default 500 EFI Fuel Rail Schrader Valve question
Does anyone know where I can get a "female" fitting to hook up a fuel pressure gauge to the schrader valve on the 500 EFI fuel rail? It's a much larger than standard diameter barrel for a schrader valve and I can't find a fitting for it-
ctuck0659 is offline
Old 12-11-2012 | 03:29 PM
F-2 Speedy's Avatar
take a look at auto meter 3280
F-2 Speedy is online now
Old 12-11-2012 | 04:16 PM
Thanks, but the standard (tire valve) size schrader valve diameter is 1/8". The diameter on the fuel rail looks almost twice that. Besides, I was hoping someone know where I could get an actual Schrader fitting to mount on the end of a pressure gauge hose-
Old 12-11-2012 | 04:26 PM
Call your local pipe supply shop or heating supply shop. as a pipe fitter we use these all the time in med gas and refrigeration set ups they should have them in various sizes
Hilgy88 is offline
Old 12-11-2012 | 05:06 PM
OK, thanks.
Old 12-11-2012 | 05:15 PM
F-2 Speedy's Avatar
the 3280 is 1/8 NPT which is larger than the 1/8 inch u refer to, NPT national pipe thread,
Old 12-12-2012 | 08:41 PM
http://www.metcomotorsports.com/prod...p?prod=MFF0001
EdNewman is offline
Old 12-13-2012 | 08:46 AM
That's what I need- Thank You!
