Installing new motor with trans help >
Old 12-26-2012 | 10:24 AM
I think I would go through that engine before I would install it in a boat. Looks to have been neglected. Noticed the date on the pics. Has it been sitting in the yard under that blue tarp for 7 years?
picklenjim is offline
Old 12-26-2012 | 12:00 PM
Yea ill crank it up before buying it so it should all bolt
Up and move 1 ft forward?
kakarot is offline
Old 12-26-2012 | 01:01 PM
mrquad1's Avatar
you will need to have inner gimble plate installed to get your measurments for engine mounts
mrquad1 is offline
Old 12-26-2012 | 02:42 PM
dammmagnum's Avatar
The matching engine to this one in the boat overheated from a crack block or some other issues in less then a couple of hours of running it, so check it out before buying it.
dammmagnum is offline
Old 12-26-2012 | 03:30 PM
Correct magnum I was told by the guy that the other motor overheated because it had a cracked block.
I meassure right now I have a 454 with alpha 1 and I have exactly 12 inches from the engine to the firewall I guess it won't fit
kakarot is offline
Old 12-26-2012 | 06:26 PM
Rookie's Avatar
Wouldn't it be easier to just bolt up a Bravo? Same transom cutout hole. +2 more holes in the transom for the transom assembly and a couple of bolts? And a better selection of inexpensive props. I think this is going to become a mess pretty quick.
Rookie is offline
Old 12-26-2012 | 08:50 PM
he should be able to sell the transmissions and ssm drives for more than the cost of bravo drives,i would think.
mike tkach is offline
Old 12-27-2012 | 09:11 AM
I guess It's better off selling my boat and buying another one with a worthy drive installed...
kakarot is offline
Old 12-27-2012 | 11:41 AM
Rookie's Avatar
Not at all. It would just be easier to install a Bravo then converting your Jaws to a transmission and #drive boat. Also as Mike stated earlier I think you would be money and labor ahead if you did the Bravo conversion.
My dumbass would run the Gen2 Alpha till it popped. Weighed the hours and cost of another Vs. the $$$ of the conversion. You have a small light boat. If you get a season or 2 out of it that is a bonus. And you can replace the upper or lower with an inexpensive SEI. I don't think you are getting much out of an Alpha selling it on Craigslist.
I would be more worried about that engine than finding a drive. Make sure it runs on a stand before you buy. Then leak down test.
http://www.sterndrive.cc/
Rookie is offline
Old 12-27-2012 | 04:21 PM
i would go with rookie's plan. plus the alpha will run bravo props. you can see how the boat likes the current prop height with that much power, then get a bravo set-up, and with a shortie and spacers you have lotsa options for x-dim.
dereknkathy is offline
