How to test manifolds >
Old 01-19-2013 | 02:28 PM
So I guess it's the manifolds leaking then..
kakarot is offline
Old 01-19-2013 | 04:50 PM
bwd
Boy! those are old Stainless Marine I think. I have a sm block set on my wall from 74 when SM was in a garage. Junk em.
bwd is offline
Old 01-19-2013 | 07:22 PM
I just took one of them off and there was some water in the exhaust part, and 3
Out of the 4 exhaust ports on the head were Wet..
kakarot is offline
Old 01-19-2013 | 09:12 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Before you turn that engine over remove the spark plugs . You don't want it to hydrolock and bend or break parts or flatten bearings . Turn it over with plugs removed to exspell any water that may be laying on top of pistons . Spray WD or Marvel mystery oil into plug holes and crank over to stop rust on cylinder walls . Get the milky oil out of her . Spray WD on exhaust valves also . Good luck . I hope you can save her .
the deep is offline
Old 01-20-2013 | 03:05 AM
I will do that tomorrow and ill remove the other manifold as well ill keep you guys posted thanks a lot
kakarot is offline
Old 01-20-2013 | 04:41 PM
Just
Took
The other manifold off and there is also water inside the manifold and the exhaust
Ports on the head are wet
kakarot is offline
Old 01-20-2013 | 06:59 PM
would be better to start the motor, even with no manifolds at all. run about 30 seconds. will blow out all the water (on the top of pistons) and the heat will dry out the little left. drain and replace the oil also. if water in oil, might take 5 oil changes to get it all out...another possibility. this is a big block. i am assuming raw water cooling, not antifreeze and a heat exchanger. salt water? or fresh? the valve guides rot out and pass water direct into exhaust passages.
dereknkathy is offline
Old 01-20-2013 | 07:18 PM
do not attempt to start the engine,as stated in an earlier post,the cylinders may be full of water,you don,t want to hydraulic the engine,pull the plugs and turn engine over by hand,use a long ratchet and a 3/4 socket on the harmonic balancer bolt.if you found water in some of the exhaust ports,id bet some got in some cylinders.
mike tkach is offline
Old 01-20-2013 | 07:23 PM
I've already cracked it up and it starts just fine, you think the valve guides might be rot? They only had around 1 hour of use since the rebuild
kakarot is offline
Old 01-20-2013 | 07:55 PM
I had a friend with an old woods truck with no manifolds on it and he started it and the noise and fire shooting out of the heads put me to my knees I was laughing so hard (with my ears plugged), I can only picture it in an engine compartment!!
Get a set of manifolds and be done with it
Mr Maine is offline
