Imco BBC Engine mounts or full offshore mount >
Old 01-24-2013 | 09:49 AM
Default Imco BBC Engine mounts or full offshore mount
Does anyone have any insite about using IMCO's engine mounts for a BBC vs a full offshore mount setup for a 620HP engine. CP performance says the imco's are fine for 620hp and others say anything 500HP or higher should be a offshore mount setup.
I would really appreciate any real world feed back on this.
http://www.cpperformance.com/p-13831...kit-black.aspx
toyo321 is offline
Old 01-25-2013 | 09:46 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I used the offshore mounts on mine just for the simple fact that this system ties both stringers together . This eliminates any flexing of the stringers or movement of the engine . Once you align your engine , drill your holes and bolt it down , it can't move . Easy and very strong . I have a set of the other mounts laying in the garage that i may put in the swap section . When given a choice between strong and stronger , i'll go for stronger every time .
the deep is offline
Old 01-25-2013 | 10:28 PM
sam,i totally agree,espically if you will see rough water on a regular basis.my single engine cat had an offshore mount and i could have the engine out in about 90 minutes.
mike tkach is offline
Old 01-27-2013 | 09:19 PM
Thumbs up Better to be safe with the offshore mount then
Thanks for the input guys. I was leaning towards the offshore mount anyway.
toyo321 is offline
Old 01-27-2013 | 10:02 PM
I'm with the offshore mount idea, I'm doing it to mine as we speak, I was going to put my 548 DART motor in the boat which makes alot of torque, so I thought I would break the pad type motor mounts. At the tail end of one of my forums I show pics of what I was doing.
http://www.offshoreonly.com/forums/s...c-owner-2.html
CAPTAIN JACK is offline
