oil coolers
Mine is in the filter pad. Seems to work fine there. Make sure you ground the pad if you don't have it mounted on the exhaust manifold (stock location). Mine is on the transom and my ground runs back to the block.
Put a temp gauge on it. I'll bet you will be surprised at how hot the oil gets.
I have just experienced this same issue. I swapped out my stock 7.4L with a 21" Mirage Plus for a 502 Mag and a 24" Bravo 1. I used all of the same components except the intake manifold and richer jetting on the 502, including the oil cooler. With the stock cooler I was seeing 230* at just a 3000 rpm cruise. At 4000 rpm or above the temp went to 260 and above. It does take a few minutes for the temps to get that high before they stabilize. IMHO the stock dual cooler on a 7.4L is just too small when any modifications for more horsepower are done.
I went the cheapest and easiest route I could to get the oil temp down. I used a CP Performance 2"X 8" (Actual cooler length is 5",$69.95) power steering cooler and a 2"X16" (Actual cooler length is 12", 89.95) oil cooler plus a permacool T-Stat. (With fittings and extra hose about $80) I went this way because I could make both coolers fit in the stock location and I could use the stock hoses with just a few modifications. The 2X12 cooler fits in the same bracket as the stock dual cooler. With the t-stat rigged onto it, the stock oil lines fit perfect. I installed the 2X5 p.s. cooler on the front of the engine and just cut out a piece of the water hose going up to the t-stat housing. I had to make a bracket out of some 1/8"X3/4" strap iron to hold the p.s. cooler in place. I also had to add some length to the p.s. hoses, too.
Now my oil is 215* at 3000 rpm, about 230* at 4000 rpm and 250* at WOT. I am happy with the results. My oil temp sender is in the remote filter pad, measuring the hot oil before the filter and cooler. I am using 15W-50 Mobil 1.
A large Eddy Marine or CP Performance cooler is probably a better way to go if you have a high HP engine. You will have close to $400 or more invested by the time you add a t-stat, cooler mounting brackets and all new custom made oil lines.
Just my .02, Good luck, Doug
First thing is to be sure to run straight 50 weight oil !!
I had oil pressure of 60-70 - After a hard run , the pressure would drop to 35 at an idle , then come back up after a minute of idling . I installed a HP Keith Eickert 3" cooler with brackets
to mount off rear bellhousng - An excellent location for plumbing
and short oil line plumbing .
Results ;
PRessure of 60-70 @ idle
After hard run , 1-2 minutes WOT , the pressure at idle
drops only to 60 lbs. @ idle
Motors HP500
Good Luck
Results ;
Motors HP500
Good Luck
Eddie Marine oil cooler. Mine was in the pan and Gary Grimes of Twister Motors (Atlanta) moved it. He located it after my Eddie Marine oil cooler. Gary said it's nice to have it in both locations. If you only have one put it right b-4 going into the engine. He told me to not run hard until I see 180* and it is starting to get hot above 230*. Remember this is after the cooler. You will see much higher temps in the pan.
I have a 540 N/A 683 hp with a Gil 14 qt pan.
My problem I don't have an oil stat. It takes a little while to see good temps to run hard. At 3000 cruise I will see about 200 to 210. Never gets over 225.
Because I said so that's why ! Just kidding! ...But since it is sitting out there in the open with a 1/4 inch of aluminum around it acting like a heat sync , I would imagine it would read a little lower than the pan where you have more volume around it. Even if its 10 degrees off its...
The sender on the remote block sees the oil temp right at the end of the hose from the block before going thru the oil filter etc I would think drop would be 1-2 degrees at most. The pat answer as you have said is "because its better" just wondered if anyone had any real hard data to back this up like "we had a temp sender in the pan and in the remote and saw this difference". I have never talked to anyone builders/owners who has ever had any data to show in the pan is better more accurate.
I am not in favour of the remote over the pan by the Way. Its just much easier to rig this to add a temp guage to an existing installation. If I was dropping in a new engine I would probably install the pan sender.
I typically see 245 WOT 220 cruise with a stock 502 Merc cooler. This is the 13 " cooler ( the 454 mag is 10" and the 7.4L is the small 8" or dual one. The 7.4 one is much to small IMO after upgradeding the engines power to answer the original question
