Garmin hooked into Smartcraft?
Does anyone know if I can connect my Garmin 740s into a 2002 496 (8.1) Smartcraft to show coolant temp, fuel flow etc?
Can the 2 be connected thru the NEMA 2000 setup?
If your 496 is nema compatible you can.u need to look for the connector on the motor.j am not sure if an 02 is.u also need a gateway to make it work..
