Gimble bearing >
Gimble bearing
Gimble bearing
Old 03-09-2013 | 10:01 AM
MER Performance's Avatar
Yes, Could not understand why, Merc went to the non grease able bearing. Maybe to save 1 machining step for the grease port in the housing. Usually the bearing for the XR has the drive side shoulder machined down on the inner bearing race. Also I have seen the engine side splined shaft show wear in the areas of the gimbal bearing surface at the o ring, which will cause chatter, indicating the universals are bad. .003-.005" wear, taper will cause this. Just something to look for.
MER Performance is offline
Old 03-09-2013 | 01:11 PM
The new Sierra brng is machined for the xr already
smokin' gun is offline
Old 03-09-2013 | 03:12 PM
mcollinstn's Avatar
While it's out...
Check the fit where the square shaft is clamped into the gimbal ring. If it's not perfect, then get a new shaft and have the ring welded and remachined for it.
mcollinstn is offline
Old 03-09-2013 | 05:24 PM
I'm not familiar with what your talking about. Ill have to get I. There and see it I can find it.
cp5899 is offline
Old 03-09-2013 | 09:42 PM
I'd assume he's talking about the upper swivel shaft. That the u-bolt clamps down.
cheech is offline
Old 03-09-2013 | 09:54 PM
seafordguy's Avatar
Put it in BACKWARDS - you'll thank yourself next time it ****s the bed....
seafordguy is offline
Old 03-10-2013 | 02:45 PM
yep! sierra one,,made by SKF...
FIXX is offline
Old 03-10-2013 | 03:02 PM
Stick your fingers in the brg. If its smooth an free of slack. I would not replace a good part that if no water has been there its fine. Just my .02 Artie
akaboatman is offline
Old 03-10-2013 | 03:11 PM
Where is the best place to buy the bearings from? Assuming you want the greasable Sierra ones.
vindicator101 is offline
Old 03-11-2013 | 09:54 AM
Artie, mine is freezing up and is very hard to turn so I'm going to deal with it now while the motor is out. I agree with you on not replacing good parts.
cp5899 is offline
