Trim Tab thru hull fitting where to by >
Old 03-25-2013 | 07:52 AM
Sick Stinger's Avatar
Brotherhood #1
Default Trim Tab thru hull fitting where to by
Have a set of K Planes and need to replace the thru hull fitting for the lines. One tab has Stainless there other had aluminum and they oxidized thru so now I have to find them. I assume they are available just not sure if its a merc thing or others would stock or have them, I.E. bam cp rex ect.
Mike
Sick Stinger is offline
Old 03-25-2013 | 08:42 AM
If you are talking about the tube that threads into the back of the tab bracket, and is threaded in the center on both ends for the hydraulic lines, I bought them through land and sea. I think they were about 25 each, I needed 4. They came stainless....
commandersander is offline
Old 03-25-2013 | 08:57 AM
Brotherhood #1
Comm have a link or part number? Also those fuel pumps you asked about are rebuiltable
Old 03-25-2013 | 06:23 PM
http://www.boatpartssource.com/pages...COMMON39629664
Hope that works.....too expensive though. My land and sea acct. Would not let me copy on ipud.....
How much for the pumps....
Old 03-25-2013 | 06:24 PM
By the way....if we are talking about the same part, it is number 6 in the schematic
Old 03-25-2013 | 06:41 PM
Brotherhood #1
20 for both ill do 90 shipped with the 2 pumps and timing cover
Old 03-25-2013 | 06:43 PM
Brotherhood #1
Yup that's it let me k ow if you can get the land and sea page up ill but from them
Old 03-26-2013 | 10:31 AM
How many do you need? I will buy and send to you. Land and sea is wholesale only (u need an account)
Go ahead with the pumps and cover...we figure out the difference.
Old 03-26-2013 | 10:38 AM
Brotherhood #1
Only need 2 ill shop your stuff today hopefully
Old 03-26-2013 | 06:42 PM
Ok....got ur pm....will order tonight.....should be here by thurs/fri latest
