Steering Rams Rebuild >
Old 04-07-2013 | 09:00 PM
Rookie's Avatar
Default Steering Rams Rebuild
It's nice to take something apart and actually finding the problem right away. Boat would drift to the Starboard side and would need to be corrected every so often.
Rookie is offline
Old 04-08-2013 | 03:53 PM
Rookie's Avatar
A trip to the local hydraulic shop.
Attached Thumbnails Steering Rams Rebuild-seals.jpg   Steering Rams Rebuild-ram-part-.jpg
Rookie is offline
Old 04-08-2013 | 03:55 PM
Nice!
You know what those parts would have cost you if your sourced through a marine outfit.....
502ss is offline
Old 04-08-2013 | 04:25 PM
hydraulics are actually fairly simple.. I was in awe when somebody posted steering cylinders are over 1500. You can coilover shocks custom made with adjustable compression, rebound and multi stage valving for less.
phragle is offline
Old 04-08-2013 | 09:48 PM
Rookie's Avatar
I understand what your saying but the custom stainless barrels, clevises, shafts and mounts is probably where the expense comes from. To make new stainless rods the my hydraulic shop quoted $400. The threaded part is a little bent on my rams.
Rookie is offline
Old 04-08-2013 | 10:27 PM
Default Me too
I need to do the same thing. Just need to find a hydraulics shop.
242LS is offline
Old 01-27-2019 | 08:40 PM
Rookie- How did you get the ends off without marring them?
endeavour32 is offline
Old 01-27-2019 | 09:42 PM
Rookie's Avatar
Pipe wrench with a sheet of urethane rubber over the teeth. I also had urethane over the jaws of the vise holding the thick end,
Rookie is offline
