Drive alignment on extension box? >
Old 04-17-2013 | 06:04 AM
Default Drive alignment on extension box?
Does anyone have or has seen a drive alignment tool for a Stellings 12" box?
Louie is offline
Old 04-17-2013 | 08:32 AM
We made one out of two pc of sliding tubing with welded plates that had the same bolt pattern as the the drive shaft. We set the angle of the solid motor mounts so the drive shaft angle was about 1 degree.
Forgot to say that we did all the X-dimension, pop testing, etc prior to the final repositioning the motor mounts.
BenPerfected is offline
Old 04-17-2013 | 11:44 AM
had to make one for my IMCO boxes, find a lathe and start cutting.
Naughty Kitty is offline
Old 04-17-2013 | 12:06 PM
just call IMCO , they have one that should fit or require minimal
modification ...
HALLETT FAN is offline
Old 04-17-2013 | 07:09 PM
You could try the ITS alignment tool. It works with both the ITS and standard Bravo's because it uses a 2 piece slide and I think it might slip in far enough to work for the extra length. The 2 piece works well too because you can leave out the piece that goes into the gimbal bearing and you can see which direction the engine needs to move to center the bar in the gimbal bearing.
Falcon is offline
Old 04-18-2013 | 06:21 AM
Thanks for the input.
Louie is offline
