Squeaky Sea pump >
Squeaky Sea pump
Squeaky Sea pump
Old 04-23-2013 | 08:39 AM
Default Squeaky Sea pump
The sea pump on my 1996 502 Mag is squeaking, but I'm still making water pressure. In a car this means it's dieing so I assume it's the same here?
If that's the case, what are my options other than a $600 replacement?
Thanks, Cole
Cole2534 is offline
Old 04-23-2013 | 09:17 AM
You can buy the bearings and seals to rebuild it for under $60
Unlimited jd is offline
Old 04-23-2013 | 09:43 AM
Awesome, thanks!
Does anyone offer this as a pre-packaged set or am I better off ordering each piece individually?
Cole2534 is offline
Old 04-23-2013 | 05:27 PM
Velocity Vector's Avatar
Crazy Energy
Originally Posted by Cole2534
Awesome, thanks!
But you have to have a $60,000.00 machine to get the bearing off.
Just kidding.
check with BAM
Velocity Vector is offline
Old 04-23-2013 | 06:05 PM
If you buy Merc parts, its closer to $200, impeller included. It is pretty easy but it requires a press.
Old Navy is offline
Old 04-23-2013 | 06:59 PM
http://www.offshoreonly.com/forums/d...fuel-pump.html
TWIN-SPINS is offline
Old 04-23-2013 | 08:44 PM
Rookie's Avatar
Here are the Merc seal part # 13 and 19. The 2 Merc inner seals (26-90562) work better than the SKF 7464.
http://www.mercruiserparts.com/Show_...%28DESIGN+I%29
Rookie is offline
Old 04-23-2013 | 09:10 PM
An engineering degree? Got one! lol
Thanks guys.
Cole2534 is offline
