max timing on 454mag MPI's >
Old 04-24-2013 | 04:23 PM
Default max timing on 454mag MPI's
Anyone out there know what the Full advance is supposed to be on 98 454mag MPI's? I guess max without causing any issues???? I would like to check
Thx.
silent lucidity is offline
Old 04-24-2013 | 07:33 PM
articfriends's Avatar
Depending where base timing is set total timing ends up around 36 degrees in the higher timing tables at 50-70 map, Smitty
articfriends is offline
Old 04-25-2013 | 01:12 AM
If its a stock engine, just set it at 8* in base timing mode and be done. Another 2* might be good for another 0.3mph and not worth it.
Griff is offline
Old 04-25-2013 | 04:14 AM
I'm used to non computer motors. Is a jumper or something that needs to be done to the computer to put in a certain mode?
Thx
Old 04-25-2013 | 08:27 AM
28Eliminator's Avatar
There is a diagnostic connector close to the ECU on the port side of the engine. You need to remove the plug end and jump a and b pins, bring rpms to 1000-1500, otherwise it jumps all over, then set the time with the timing light. Merc makes a tool that you can plug in for $10-15, 805747A2
28Eliminator is offline
Old 04-25-2013 | 08:59 AM
Cool that's what I needed thanks
Old 04-25-2013 | 09:03 AM
last question,, if bringing it up to 1000-1500 rpms to set initial 8*
Wont that speed (1000-1500) start bringing in advance or is that what the tool is doing is stopping any advance?
Old 04-25-2013 | 09:11 AM
no, the jumper locks the ECU from changing the timing. The timing won't move even if you rev it up to 3000rpm. One other thing, mine does not idle very good and will die at idle sometimes when the jumper is in, so just rev it up and set the timing.
Old 04-25-2013 | 09:17 AM
