need adjustable FPR on 496ho raylar103kit ? >
Old 05-01-2013 | 10:48 AM
Default need adjustable FPR on 496ho raylar103kit ?
I would like to know if i need a adjustable fuel pressure regulator to increase the psi in fuel system...?
Ive hearded about drilling a bigger hole in the throtle body to fix the idle issue...
hooray is offline
Old 05-01-2013 | 10:54 AM
On my kits , I had to use adjustable fuel regs.
DOUBLE OR NOTHIN is offline
Old 05-01-2013 | 10:57 AM
What year 496? What is the actual current fuel pressure key on engine off?
Dont you have an adjustable regulator on the rail?
(#10 star)
Keith Atlanta is offline
Old 05-01-2013 | 11:23 AM
496 ho 2009, no fuel pressure gauge yet!
Never had any issues with the engine but i just want to make sure im not too lean.
Thx!
hooray is offline
Old 05-01-2013 | 11:33 AM
Thx!
I think after 2005/2006 they did a pre-set regulator.
If it is running, leave it alone, dont start fooling with 2 regulators. The only way to know is put an A/F bung and get some numbers.... Dont start running all kinds of irradic pressures. You can take the rail off, cut the current regulator off (little round black thing on the rail) put an AN fitting and get an Aeromotive (or similar) but it will create irradic pressures at other RPM levels.
I sent you a link PM to an Aeromotive 496 setup...
Old 05-01-2013 | 11:36 AM
Thank you Keith! Its very appreciated
hooray is offline
