Erratic Vaccuum readings >
Old 05-18-2013 | 04:08 PM
  #31
Well I pulled the valve out and found pitting on the stem. Same valve bent last year so I had a valve job done and it ran fine the rest of the year. The mechanic didn't tell me why the valve bent, maybe it stuck first. Coincidence that it should happen to the same valve? What causes that? Is there something wrong with the head / guide?
Seahawk 2000 is offline
Old 05-18-2013 | 08:45 PM
  #32
GPM
What brand valves are you using, are they Inconel ?
GPM is offline
Old 05-18-2013 | 10:22 PM
  #33
That's what I was told.
Old 05-19-2013 | 08:26 PM
  #34
GPM
Did you stick a magnet to it to see what it does, you might want to look at all of the valves.
GPM is offline
Old 05-20-2013 | 03:46 PM
  #35
What should the magnet do?
Old 05-20-2013 | 04:22 PM
  #36
GPM
Nothing if it's inconel.
GPM is offline
Old 05-20-2013 | 10:08 PM
  #37
It's not magnetic.
Old 05-21-2013 | 04:11 PM
  #38
Old 05-21-2013 | 05:07 PM
  #39
GPM
Inconel doesn't rust.
GPM is offline
Old 05-21-2013 | 08:08 PM
  #40
I didn't notice any rust. I could put it in water and see what happens.
