Push-On hose for fuel plumbing? >
Old 05-21-2013 | 10:15 AM
Brian, I'll be using 1/2" and 3/8". Thanks for the help.
Cole2534 is offline
Old 05-21-2013 | 10:56 AM
These are the Oetiker stainless steel band clamps that I have found to work the best for the Telflex hose. We us # 16702498 or (16700022) for the 3/8 hose and # 16700026 for the 1/2 hose.
brian41 is offline
Old 05-21-2013 | 04:35 PM
I would use clamps as well....used for all my oil lines, worked great..but one came off at block adapter...summit replaced all the hose, used aeroquip after the summit brand..but did clamp all !!!!
ezstriper is offline
Old 05-24-2015 | 05:27 PM
Bump. Thinking about using AQP socketless on my oil cooler/filter setup with a 212* thermostat. I shouldn't have any issue at that temp, correct?
Aeroquip hasn't been very timely with a reply to my question about its operating temp.
Cole2534 is offline
Old 05-24-2015 | 06:09 PM
AQP socketless is rated to 300 f
Been using for many years.
Jeff
hallj is offline
Old 05-24-2015 | 06:38 PM
Excellent! Thank ya kindly.
Cole2534 is offline
Old 05-24-2015 | 06:51 PM
[Code of Federal Regulations]
[Title 33, Volume 2]
[Revised as of July 1, 2001]
From the U.S. Government Printing Office via GPO Access
[CITE: 33CFR183.540]
[Page 780]
TITLE 33--NAVIGATION AND NAVIGABLE WATERS
CHAPTER I--COAST GUARD, DEPARTMENT OF TRANSPORTATION (CONTINUED)
PART 183--BOATS AND ASSOCIATED EQUIPMENT--Table of Contents
Subpart J--Fuel Systems
Sec. 183.540 Hoses: Standards and markings.
(a) ``USCG Type A1'' hose means hose that meets the performance
requirements of:
(1) SAE Standard J1527DEC85, Class 1 and the fire test in
Sec. 183.590; or
(2) Underwriters' Laboratories, Inc. (UL) Standard 1114.
(b) ``USCG Type A2'' hose means hose that meets the performance
requirements of SAE Standard J1527DEC85, Class 2 and the fire test in
Sec. 183.590;
(c) ``USCG Type B1'' hose means hose that meets the performance
requirements of SAE Standard J1527DEC85, Class 1.
(d) ``USCG Type B2'' hose means hose that meets the performance
requirements of SAE Standard J1527DEC85, Class 2.
Note: SAE Class 1 hose has a permeation rating of 100 grams or less
fuel loss per square meter of interior surface in 24 hours.
SAE Class 2 hose has a permeation rating of 300 grams or less fuel
(e) Each ``USCG Type A1,'' ``USCG Type A2,'' ``USCG Type B1,'' and
``USCG Type B2'' hose must be identified by the manufacturer by a
marking on the hose.
(f) Each marking must contain the following information in English:
(1) The statement ``USCG TYPE (insert A1 or A2 or B1 or B2).''
(2) The year in which the hose was manufactured.
(3) The manufacturer's name or registered trademark.
(g) Each character must be block capital letters and numerals that
are at least one eighth-inch high.
(h) Each marking must be permanent, legible, and on the outside of
the hose at intervals of 12 inches or less.
[CGD 85-098, 52 FR 19728, May 27, 1987]
Bawana is offline
Old 05-24-2015 | 07:28 PM
[Page 780]
requirements of:
Sec. 183.590; or
Sec. 183.590;
party pooper.
sutphen 30 is offline
Old 05-24-2015 | 08:30 PM
Teague has everything you need. And the hose even says us coastguard approved.
KWright is offline
Old 05-24-2015 | 09:28 PM
SB
One day in band clamp..........
SB is online now
