Intake Erosion >
Intake Erosion
Intake Erosion
Old 07-29-2002 | 07:19 AM
BETTERTON
Default Intake Erosion
HOW LONG WILL AN AUTOMOTIVE STYLE DART II LAST IN A MARINE INVIOROMENT? WHAT OR HOW DOSE MERC TREAT THESE MANIFOLDS ON THE HP 500'S TO MAKE THEM LAST?
Old 07-29-2002 | 07:37 AM
Ted G's Avatar
Less than a season on the Chesapeake-even with flushing.
Sorry, I cant help you with the coating part.
www.cbpba.com
Ted G is offline
Old 07-29-2002 | 08:30 AM
GregP's Avatar
Less than a season? Am I real lucky or were you real unlucky? I have going on 4 years now on the Edelbrock manifolds, and when I pull the water outlets and look inside they still look ok. The boat had Holley manifolds on when I got it, and they were in pretty good shape too, boat was run on Long Island sound before I got it, but did set for a couple of years unused.
I am "pretty good" about flushing the motors after each run, and live several miles up-stream from the bay itself so the water is probably a little less salty at my dock.
-Greg
GregP is offline
Old 07-29-2002 | 12:36 PM
BETTERTON
I SURE HOPE YOUR 4 YEARS PLUS IS ACCURATE. SO FAR MINE ARE ON THE SECOND SEASON. I TOO USE A RAMP FAR FROM THE SALT LINE ON THE CHESAPEAK BAY, TOLCHESTER, MD. IS THE SALT LINE MOST OF THE TIME. WHEN I PUT IN AT THE KENT NARROWS I ALWAYS FLUSH WHEN I PULL THE BOAT OUT. HOPE IT HOLDS UP.
Old 07-29-2002 | 06:06 PM
Ted G's Avatar
I had erosion around the bolts and in a sender port after 1 year on a SBC manifold. I gave uup and went back to a cast iron manifold. Maybe I was real unlucky but I have seen some pretty hideous aluminum manifolds on the Bay.
www.cbpba.com
Ted G is offline
Rambunctious
5
12-13-2007 09:35 PM
Pat McPherson
14
10-04-2005 10:03 AM
PatriYacht
Prop Talk
17
06-10-2005 09:51 AM
MitchStellin
12-13-2004 09:33 AM
nobudget
2
04-21-2002 09:53 PM
