What is this hose that broke off my Bravo 1 gimbal? (pic)
Thanks guys, it finally paid off to never throw anything away.... :-)
I have a junk gimball with that part still on it, so I just took that one. Excellent help guys!
Regards,
Johan
Regards,
Johan
Speedo hose broke, would water infiltrate inside boat?
I agree with others. That is the "Pitot tube" for the boats speedometer.
More importantly. Since no one else has mentioned it. Ensure you repair it or cap it off. If not its a very interesting water leak! It will only leak when moving forward*...the faster you go the more water it will spray!
* - unless your boat sits low enough in the water that the water line is above that tubes height when sitting still. Then it will leak when sitting still in the water.
Can water infiltrate into boat with this line broke at fitting on outdrive?
