Alternatives to Procharger intercooler
http://www.alcoholinjectionsystems.com/index.html
Meth is the answer, it will make your motors so happy and last longer!! Talk to Rodney there he rocks!!!!! :-) :-) They have some new tanks not on web page yet they are Awsome and have all the right baffling in them for a boat :-)
I'm familiar with the Procharger intercoolers.
I could make up a core unit of finned cupronickel tubing that would fit inside of the housing. From the outside it would "be" a Procharger intercooler, but all of the water passages would be corrosion resistant cupronickel. The housing of course would still be aluminum but would only see hot air - not water.
The finned cupronickel tubes could be stacked and staged to allow the coldest water on the "exit" end of the airflow and the warmed water to exit on the entry end of the unit - this would spread the cooling delta all the way thru the core.
I haven't done one of these, but I would say I could do so for no more than the cost of a standard replacement unit.
MC
MC
coolingmist.com
I have one of these setups on my Grand National, and run it with straight Methanol. You will be able to turn up the boost if you so choose to do so and still have a huge safety margin. Methanol is cheap and you don't use a lot of it either.
Their system is totally programmable, and only come on when you need it.
got a friend that ran one of thease in his zx for a few yrs..worked gr8..http://www.frozenboost.com/index.php...0a99242d95ac1b
Fixx,
Was he running one of their intercoolers in salt water? My boat goes in for three days then comes out and gets flushed. The frozen boost stuff is inexpensive but I worry about longevity.
im thinking a on board liquid nitrogen tank cooling the water for the intercooler might work.
