sealer for cockpit floor ? >
Old 06-22-2013 | 11:01 AM
bck's Avatar
bck
Charter Member#568
Default sealer for cockpit floor ?
I took out the center section of removable floor to inspect the tanks and drainage. Is there any particular kind of sealing product I should use to put it back together? The old stuff seemed like plain silicone caulk. Thanks
Straight bottoms and flat decks
bck is offline
Old 06-23-2013 | 07:49 PM
Rookie's Avatar
I would suggest 3M 4200 If you want to remove again in the future.
3M 5200 if you never want to open it again.
Rookie is offline
Old 06-23-2013 | 08:25 PM
c_deezy's Avatar
Life Seal, 3M Marine Sealant or the like. I wouldn't use 4200 as it is still an adhesive.
c_deezy is offline
Old 06-23-2013 | 09:21 PM
you have enough surface area the even with 4200 you may never get it open again
phragle is offline
Old 06-23-2013 | 09:42 PM
bck's Avatar
bck
Charter Member#568
I'd like to say I'll never open it again but I know I'll have to so that definitely rules out 5200 and I guess 4200 as well just to be safe.
bck is offline
