Grease points on Bravo? >
Old 07-03-2013 | 08:00 AM
Default Grease points on Bravo?
My Alpha has zerk grease fittings for the swivel pin, hinge pins and lower bushing but my Bravo doesn't. Why did they get rid of these grease points? Does anyone use any spray lube on these points or just let them wear?
Mr Maine is offline
Old 07-03-2013 | 09:05 AM
Well, the pessimistic side of me says that Merc did this to keep us buying new transom assemblies from them. A buddy of mine actually drilled out his lower ring with a flat tipped bit and added a zerk fitting. I might do the same to mine. I agree that it is asinine that they eliminated the ability to lube such a critical joint on the transom assembly.
Budman II is offline
Old 07-03-2013 | 09:37 AM
Okay, glad I'm not the only one. I have just rebuilt the transom assemblies and want to try to keep them from wearing out. I may add fittings or spray with some sort of lube occasionally
Mr Maine is offline
Old 07-03-2013 | 10:02 AM
On the HP transom assy, the bushings are made of a material like fiberglass. It seems that it would attract dirt and wear out quicker if greased, as there are no seals.
Old Navy is offline
