Bravo Drive
Old 07-31-2002 | 10:09 AM
PanteraInVentura
Default Bravo Drive
I am such a rookie, but what is the proper maintenance for a Bravo drive, oil maintenance, which zerk fittings to pump grease in and what kind and when to grease. Also any preflight examinations. That sort of thing.
Thanks Again!
Old 07-31-2002 | 05:33 PM
bimini run's Avatar
I'm a rookie too, but here is what I have learned.
At least annually (I do this during winterization):
Grease all fittings. Do not forget the engine couplings (2) behind the block. They are a real ***** to get at, but I have heard of them (engine coupler) going bad. Bump the engine to get at them. Also, (I guess) the drive should be removed to grease the u-joint.
Change drive oil
Replace zinc fittings as required. If boat is kept in water, I would do this once a year.
Remove prop during winter storage.
Touch up with paint as required.
Get the maintenance manual - it tells you exactly what needs to be done.
bimini run is offline
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
1BIGJIM
Wanted
10
05-16-2008 10:12 AM
rhory
1
05-19-2004 06:52 AM
Chris288
1
04-13-2004 11:19 AM
panteraracin
3
02-07-2002 10:36 PM
