inner transom plate >
inner transom plate
inner transom plate
Old 07-18-2013 | 12:07 AM
Unhappy inner transom plate
Good evening to everyone looking for some guidance in replacing a inert transom plate on a baja 235 with an alpha one,the inner plate is cracked at the steering bolt will I have to remove the engine to replace the transom plate or just the alpha ?
chrisborges007 is offline
Old 07-18-2013 | 06:53 AM
Both will need removed to replace the innner transom plate.
Ryan00TJ is offline
Old 07-18-2013 | 07:18 AM
carter38's Avatar
Check for flatness of the transom alot of times the transom is not flat and thats what causes them to break. Hope it's not in need of a new transom.
carter38 is offline
Old 07-18-2013 | 07:30 AM
Not trying to hijack your thread but are a Alfa and a B1 inner transom sheld the same?
blown wages is offline
Old 07-18-2013 | 08:02 AM
no,they are different.
mike tkach is offline
Old 07-18-2013 | 08:43 AM
No what causwd the break was a bad steering cable and the wheel was forced causing the crack at the join
Old 07-19-2013 | 11:01 AM
I changed mine without removing the engine. The engine did need to be un bolted and jacked around to get the job done, and it was a PITA, but I got it done. Mine has through hull exhaust only.
Jeff
sbslinde is offline
