Cleaning vinyl? >
Cleaning vinyl?
Cleaning vinyl?
Old 07-28-2013 | 08:02 PM
Default Cleaning vinyl?
Can anyone recommend a good cleaner to clean white vinyl seats and sun pad? I tried black streak remover, Attwood vinyl cleaner and Soft Scrub. The first two didn't do much. Soft Scrub did remove some of the strains but not everything.
underpsi68 is offline
Old 07-28-2013 | 08:18 PM
I use Spray Nine marine with great results.
bonesmalon is offline
Old 07-28-2013 | 08:43 PM
Spray 9 with mr clean magic eraser. Usually go over it with 303 protectant when done to get the uv protection back.
wwolfe is offline
Old 07-28-2013 | 08:44 PM
I have amazing results with "awesome orange" and a green "scotch-brite"scrub pad. It gets out grease, oil, mold, mildew, and other stains. Others have good luck with "simple green" or a "mr clean magic eraser." No matter what you use to clean it make sure you treat it with a good vinyl protectant after to seal it. I use "303" marine vinyl protectant, a little pricey but it is good quality stuff and cost is offset by the dollar bottles of the cleaner. Hope this helps I am sure others with chime in there are hundreds of posts about this use the search tool.
LiveFREEorDIE is offline
Old 07-28-2013 | 08:51 PM
+1 on the magic eraser followed by 303 protectant. I also use 303 vinyl cleaner and simple green.
WHIPLASH is offline
Old 07-28-2013 | 09:06 PM
t500hps's Avatar
21 and 42 footers
Magic eraser with most anything works awesome however, they also remove alot of the natural oils in the vinyl so you MUST apply conditioners once clean.
t500hps is offline
Old 07-28-2013 | 09:14 PM
Magic eraser and a oxycleaner and elbow grease.
ckelly70 is offline
Old 07-28-2013 | 10:56 PM
Manic eraser will rot your tread away.... Use it sparingly
mptrimshop is offline
Old 07-29-2013 | 05:25 AM
Thanks for all the suggestions!
Old 07-29-2013 | 07:58 AM
Is the Mr. Clean magic eraser safe to use on the colored vinyl as well? ie: the blue fountain logo stitched into my sunpad?
HyFive578 is offline
