Block Pressure zero? >
Old 08-07-2013 | 04:29 PM
Default Block Pressure zero?
Trying to find 2beeps/sec problem. 496 HO. Scan shows pitot active. I understand this is normal? Scrolling thru data shows block press zero. Is this normal? What should the range be? Where is the sensor?
miwettig is offline
Old 08-07-2013 | 06:49 PM
Yeah your pressure sensor crapped out... Its way down there too, my buddy had his on the sea water pump.
Back4More is offline
Old 08-07-2013 | 08:12 PM
On my 2002 496 the sensor is on the sea pump, starboard side, bottom front. You can see it just behind the fuel filter.
underpsi68 is offline
Old 08-07-2013 | 09:57 PM
I replaced both sea pumps this year don't recall any sensors unless it's the small hose on top?
miwettig is offline
Old 08-08-2013 | 02:14 AM
older 496,s have the sensor on the power steering cooler
TWIN-SPINS is offline
Old 08-08-2013 | 08:36 AM
Mine are 2005. Part no.8M600023 is on the power steering cooler. Is that it? Is it looking at a 'blockage' or something to do with the block?
miwettig is offline
